hydraulic lever extensions
   / hydraulic lever extensions #11
I think I understand what you mean.
right now I have a seperate valve inline to the hyd. loop. it has two outputs, that go on a seperate hose to the plow and I use it for swinging the plow. If I were to place a T into the outlets, I dont see how it would be different than running 16 feet of hose from the tractor front to the rear to run the piston.
The oil would have to go through either hose. And if the plow cylinder was disconnected, It should go to the rear hoses and cylinder.
I would have to disconnect the rear cylinder tho to use the plow swings.
Does this make any sence?
Thanks for your post.
Allan
   / hydraulic lever extensions #12
Sounds like you have one rear remote.
Teeing into either of the work ports (the 2 outputs as you call them) will not give you an additional function. What it will do is enable you to use that same function for different implements, say one in the rear or one in the front. The only catch is that you cannot have both implements connected at the same time, as you pointed out.
However, you can get a hydraulic multiplier from V & M Inc. that will work similar to a diverter. Take a look see.
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
NEW Woods 6ft Finish Mower (A55301)
NEW Woods 6ft...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
