Hydraulic line wear
   / Hydraulic line wear #31
Then why did they move?
Good question.
Probably because the hoses move quite a bit when pressurized. In fact, you can see the movement it in the wear pattern on the hose.
It's time to put a radius on that bracket - or cut the front off and replace with a large thru bolt and rotating pipe.
Add heater hose if there is room.
Replace the worst of the hoses - it won't last the year. You can have one made at our local hydraulic shop for 20/30 bucks. Watch the others.
luck,
rScotty
   / Hydraulic line wear #32
take a look at how the high quality tractors secure the hoses, any difference to yours?..
Sounds like you got it done and that's all you really needed. Good luck.
Thanks. Just pisses me off this could have been solved at the factory for $1 or less of material.
   / Hydraulic line wear #34
it's about profit, they'd have to charge $1 more, and would be out the replacement sale of the hoses that wore out!.:eek:
1/2'' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2'' Wolverine...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
2012 Ram 3500 Chassis Pickup Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500...
LOOK! (A53342)
LOOK! (A53342)
