Hydraulic lines (3/8 vs 1/2) when to choose one over the other??
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I am at the end of a disk restoration (JD 225 8' offset) The old hydraulic lines were 3/8. The swivel type of connection I wanted to use to connect to the cylinder was only available at my tractor dealor in 1/2" line size so I had them make me 1/2 inch lines to replace the 3/8" lines that were origionally on the disk. Then I started thinking about the differences and wondered if there is any reason I shouls not do this. The lines are definately more "bulky" and upon examination of my tractor, I noteded all the lines to my FEL are 3/8". What is your opinion? When would you want to use a 1/2 rather than a 3/8 and vice versa??? thanks
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #2
It has been recommended to increase the size of QD's one level up, so as not to restrict any flow. The reason that most people don't do it is cost. If the cost difference is minimal, then do it.
Sounds good. What is QD ? sorry for my ignorance
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #4
Quick Disconnect
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #5
production ,bigger lines faster pick up at the ends turning around.
So it looks like my switch is mostly a good thing? Regarding pressure, someone mentioned the smaller line was rated for more pressure. I dont suppose the weight of my 8 ft. disk could induce more pressure than 1/2" line will handle????
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #7
I do not belive this to be true. I mean the part about smaller lines being capable of greater pressure.
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #8
The pressure has to do with surface area. A smaller hose will handle larger pressures. A lot of the rams use 10,000 psi hoses. I don't think you will see that in a 1 in hose.
If you look through the hyd hose catalog, you will see the difference, providing everything is the same type hose.
http://www.gates.com/brochure.cfm?brochure=916&location_id=535
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #9
my tractors operate with less than 3000 psi at the coupler . some of my hoses are bigger than a inch .the hoses i buy are rated for the same pressure whether it is 3/8 0r 1 in.it is stamped on the hose. bigger hoses = faster pick up.
   / Hydraulic lines (3/8 vs 1/2) when to choose one over the other?? #10
it deals with fluid dynamics. larger size inside diameter hose = less friction loss, along with capacity.
a larger size hose that is rated at same max psi pressure, will be more expensive, but can provide better performance for say using hyd motors. were fluid is constantly being pumped through the lines.
when it comes to hyd cylinders, larger size hose rated at same max psi. = quicker fully extending / contracting. will you notice the difference, to many variables. perhaps when the tractor is barely able to lift a 3pt hitch. and that tractor is struggling, you might notice a difference
note i mentioned inside diameter. outside diameter, does not matter.
just remember though larger size rubber hoses. as they age. could collapse and have more fluxtations. for example going down a bumpy road. with a heavy 3pt implement. may cause larger diameter hose to collaspe before a smaller diameter hose. when you go over a bump and all the weight of imlement plus the moment plunges downwards. and if not collaspe may allow the 3pt implement to bounce more. causing a rougher ride or perhaps slower driving to keep things safe. reason being is rubber hoses are just that rubber and they can expand / contract some. a solid rigid metal pipe will not flex. (well they can, but when they do, you normally have to replace them *doh*)
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2001 New Holland TN75 Farm Tractor (A57453)
2001 New Holland...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
Forklift (A59228)
Forklift (A59228)
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
25ft Tag Trailer (A56436)
25ft Tag Trailer...
