Hydraulic Motor for Winch
   / Hydraulic Motor for Winch #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Help Guys!
How do I calculate the size hydraulic motor needed to power a 2000# winch I have with a burned out electric motor? I have 2000 PSI at 6 GPM available. I would direct couple to the winch shaft so no loss in the drive mechanism. Would putting a flow restrictor in the forward and reverse lines increase the motor size requirements?
Thanks for advice in advance.
Ron
   / Hydraulic Motor for Winch #2
You would need to know the torque of the electric motor, and find hyd motor with same or greater torque.
The hyd motor speed will be based on the GPM's that you supply.
Torque on a hyd motor will be fairly constant from 0 rpm to max rpm.
Here are some hyd motor you might look at.
Surplus Center
Surplus Center
JJ, Thanks, that helps some. Could't determine torque but the electric motor is 1 HP at 12V DC
Ron
   / Hydraulic Motor for Winch #6
J.J--
Military winches come up for sale pretty often for cheap. They are 24v for the diverter hyd winches. They are designed to run off the power steering pump of a humvee. Do you think the rear remote or 3rd function couod be adapted to power it on a tractor?
Brett
   / Hydraulic Motor for Winch #7
The 24 v motor just might run off 12, at half speed.
You could put two 12 v batteries in series for 24 v.
   / Hydraulic Motor for Winch #8
All the 24v power does is power the solenoid. It's a hyd winch. Fluid goes in and the solenoid diverts it to in or out by using the remote. It will work with 12v, just wondering about powering the hyd off my tractor
Here's one for visual reference. When I got my tractor stuck this wouldve been helpful
Military Truck Parts 10 500 lb Hydraulic Winch M998 NSN 2590 01 485 8343 | eBay
Brett
   / Hydraulic Motor for Winch #9
J.J--
Military winches come up for sale pretty often for cheap. They are 24v for the diverter hyd winches. They are designed to run off the power steering pump of a humvee. Do you think the rear remote or 3rd function could be adapted to power it on a tractor?
Brett
Find out what the Humvee power pressure is and then set a relief for the winch to that figure.
You can vary the tractor GPM output by setting the engine speed.
3rd function would work, just switch it on and control the hyd flow with a valve.
Volume of hyd flow will dictate the winch speed.
Year: 2003 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A44572)
Year: 2003 Make...
2006 Ford F-450 9ft Flatbed Truck (A44571)
2006 Ford F-450...
STORAGE FEES (A43004)
2000 Chevrolet Express Van, VIN # 1GBHG31R5Y1108573 (A44391)
2000 Chevrolet...
2008 Ford F-250 Pickup Truck, VIN # 1FTNF20598EA54729 (A44391)
2008 Ford F-250...
2014 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2014 INTERNATIONAL...
