Hydraulic motor - low power
   / Hydraulic motor - low power #1
Krookz
Va
John Deere 17D. Kubota L275
Hey guys. Trying to search hydraulic motor low power/low torque dosnt return wanted results so I figure id ask.
I have a digit 158 towable backhoe. Boom/bucket/stabilizers have good power and speed. Pump has a drip or two of oil when running, I do not suspect this to be the issue since other owners of the same machine have the same issue.
Machine has good speed on level ground. But if the wheel gets in a small rut or has to power over a stick/root it will not turn over. Wheels will not spin so traction isnt the issue. I replaced one wheel motor when I bought the machine, the internals on the old one were bad. System pressure is 2500psi. Im thinking there might be some kind of purposeful restriction on the valves but im not sure where to look or what to check for. Any ideas/thoughts? There's no separate relief valves for the wheel motors.
   / Hydraulic motor - low power #2
Why not put a gage in the wheel circuit and see how much pressure is being generated.
Do you know of any restrictions in the flow path.
Every hyd circuit should have a relief valve. A relief valve is necessary to protect the pump.
There is one relief valve, what I meant is there isnt additional for the motors.
Ill put the gauge at the end by the motor and see what it comes out as this weekend. I dont know of any restrictions, and the manual dosnt list any separate parts on the tree for the wheel motors
   / Hydraulic motor - low power #4
Is there only one pump?
Only one pump. Same results of I only use one motor
45'x25' Metal Garage (A53316)
45'x25' Metal...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
48" WIDE WOODEN W/ METAL RAILING (A54756)
48" WIDE WOODEN W/...
Tradewinds Power Unit (A50120)
Tradewinds Power...
