muddstopper
Veteran Member
One thing I have seen before and is very hard to find if your not looking right at it. I have seen little pin holes in hoses that dont spray a stream. More of just a mist. If you not looking at it, you wont see it, but you should smell it. If the mist is directed away from the machine, it might not even show up as a streak running down the hose. It also wont spray if there isnt any pressure on the hose when your looking for it. Get someone to operate the hyd while you are looking, what ever you do, dont run your hands over the hoses looking for the leak, That mist is under high pressure and will inject into your skin.
