hydraulic power to quick attach implements?
   / hydraulic power to quick attach implements? #1
o2batsea
Platinum Member
Maryland
Kioti DK45C 2005
Is there anything that would allow one to have a separate hydraulic line to the front of the loader for powering attachments? Can you tap into the hydraulic circuit for the FEL? I assume that you'd have to have another joystick controller for the implements circuit. Does Kioti make a kit for this? I've tried to see anywhere that I could take hydraulic power, but other than the rear outlets for the backhoe I can't see any place.
I'd like to have a grapple attachment on the loader for clearing downed logs and slash.
Tractor is a 2006 DK45 Cab with loader and backhoe. Thanks.
   / hydraulic power to quick attach implements? #2
WR Long makes a kit that sounds like what you are looking for.
Valve Kits
   / hydraulic power to quick attach implements? #3
If you want a "kit" then the WR Long valve is the way to go...or you can homebrew your own setup. Do a search for these terms for HOURS of reading:
diverter
3rd function
grapple
markham
millonzi
tatro
   / hydraulic power to quick attach implements? #4
MyDK40SE came with a rear remore already in place from the factory....I added a grapple attachment at time of purchase which my dealer plumbed lines from to the front....these in-turn accept the quick plug in coming from the grapple. The remote lever controls the grapple "fingers" and the joystick does the normal operations for the loader"lift and tilt.
I have been very pleased with this set up and allows for quick change back to the bucket. I know Kioti can add rear remotes for their tractors as I almost had the dealer add a second set.
Sandpiper 20' Sailboat (A44502)
Sandpiper 20'...
3000 Gallon Black Poly Water Tanks (A45336)
3000 Gallon Black...
Hiniker 15’ Stalk Chopper (A47369)
Hiniker 15’ Stalk...
2011 Ford F-250 Pickup Truck (A44572)
2011 Ford F-250...
2025 KJ K2119 UNUSED Double Garage Metal Shed (A47484)
2025 KJ K2119...
2025 Wolverine SBM-12-72W Sickle Mower Attachment (A47484)
2025 Wolverine...
