Hydraulic pressure from divert low? F22
   / Hydraulic pressure from divert low? F22 #1
guyd
Bronze Member
Hi
my F22 has a hydraulic divert lever under the seat, which switches on a pair of ports, which I have used for the FEL. All works as you would expect, except the lift capacity is poor. is this divert thing limited - or is the main hydraulics suspect? I compare it to my last tractor, with the same loader - a YM1510
guy
   / Hydraulic pressure from divert low? F22 #2
Plug in a hyd gage and check the pressure.
   / Hydraulic pressure from divert low? F22 #3
You also maybe able to adjust the pressure at the FEL joy stick. I had to increase mine this week so my FEL would pick my trailer up to install new axles
pressure relief valve on joystick wound all the way in. I dont have a gauge - ill see if I can beg borrow steal one from the local dealer. Any idea what the pressure should be?
   / Hydraulic pressure from divert low? F22 #5
I have no information on an F22 but a YM220/222, same horsepower range, relief pressure on 3 point is a little over 2200#. I would just guess yours to be in that range. Maybe there is somebody out there with an F series manual.
Well - I bought a gauge and installed it on the lift hose - 2200psi - and 1800 on the 3ph auxiliary out (the one you use for tipper trailers etc) - which is a bit weird that the 3ph is lower than the FEL.
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
