hydraulic problem with my 3 point hitch farmpro 2420
   / hydraulic problem with my 3 point hitch farmpro 2420 #11
If you replaced the pump and it is a good pump, and if the IN port is flooded, then when the engine is turning, the gear pump is turning, or should be pumping.
With all levers in neutral, there should be flow, but very little pressure. Now when you operate the loader, the loader should work and build pressure depending on load.
A hyd gage will tell you if you have pressure.
   / hydraulic problem with my 3 point hitch farmpro 2420 #12
Hello, I'm new to tractors but have a FarmPro 2420 2WD and the lift arms located at the back of the tractor just stopped working one day while I was connected to an Augger* digging holes for post to go in. I took apart the covers under and in front of the seat just to make sure everything was alright and it is. I then connected a hydraulic gage to the pump quick connect line and no pressure was showing so I replaced the pump and still nothing. I also checked the o-rings and they look fine and dandy. What else could it be? Please help, I have much work to be done. :/
hey did you ever discover the problem? Mine stuck in the up position this am.
let me know
2013 Buick Enclave SUV (A55853)
2013 Buick Enclave...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A56129)
2020 KENWORTH T680...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A56129)
2012 FREIGHTLINER...
SDLanch SDLD25 (A53316)
SDLanch SDLD25...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
