Hydraulic Pump Filters?
   / Hydraulic Pump Filters? #1
akadave
I am putting a double action pump on a 5 1/2 inch OD by 30 inch cylinder. The question is do I need to put a suction strainer or return filter or both or something else on this thing. Seems if you start with a clean cylinder, clean fluid, a clean reservior then filters may not be that big of a deal but I don't want to damage anything.
This is for a dump trailer. I also considered going with a single action pump and gravity down but the cylinder is designed to be wet on both sides and I likely risk damaging the seals if the power down side is not full of fluid. Comments on that?
Any thoughts would be helpful.
   / Hydraulic Pump Filters? #2
You will ingest dirt through the breather and rod seal. You can think of a filter as insurance. You need to determine if a small investment is worth saving the pump, valve and cylinder seals.
In a perfect world you would put the filter after the pump and before any valves. (or a filter between every component! :) ) In the real world inlet strainers can cause pump cavitation, especially in cold weather. Filters after the pump need to be high pressure, which = $$. So we are left with a return filter, which is what most off-road machines have. For a system with a gear pump you should get a filter with a 10 micron rating, unless the area is really dusty then you should get 6-8 micron.
As far as keeping both sides of the cylinder wet I don't have any personnal experience, but I'm guessing the seals and wear bands (if equipped) are designed to run wet. Maybe you can replace the seal with one designed to run dry?
ISZ
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
2017 KUBOTA SVL95-2S SKID STEER (A52707)
2017 KUBOTA...
48" HYD MINI ANGLE BLADE (A52706)
48" HYD MINI ANGLE...
New/Unused 2 Post Car Lift (A54865)
New/Unused 2 Post...
2012 CATERPILLAR 305DCR EXCAVATOR (A52707)
2012 CATERPILLAR...
