Hydraulic question on a Kubota M 6800
   / Hydraulic question on a Kubota M 6800 #41
JJ & Slowzuki,
Thanks for explanations. I've learned to live with the operation of the 3pt, but may get it checked if I have it at the local dealer.
I'm still interested to hear any more info about the 3pt and the grain drill.
Thanks
   / Hydraulic question on a Kubota M 6800 #42
Totally agree Paul.
"it's calm, normal, held in place mode", you almost said neutral here didn't ya ? :laughing:
HCJ, does it really struggle to get to the 'lever/handle' position ?
Have you tried like a 7/8ths type position (slightly lower then very, very top) in your lever/handle to see if this repeats ?
And finally, does it make any type of noise like it's going it to relief ?
I have a Kubota M6800 and if the position linkage is not adjusted properly & you lift the arms all the way up the bypass valve will kick in & you can hear a faint clicking noise. It will do this even when the is nothing hooked up to the 3pt hitch. If you push the lever just slightly off of the full up position it will stop bypassing. You will be able to hear the difference if this is what is happening.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
