Hydraulic repair help!
   / Hydraulic repair help! #11
Shucks, simply remouve the line and get the damaged area brazed.
Better yet get a similar sized steel tube, maybe 2 inches long, split it and while clamped in place braze it on as a patch.
Bet that as a repair it would oulast the rest of the tractor.
Naturally everything needs to be squeeky clean for a good repair.
Then flush the line to remouve any contaminants (gas, varsol etc).
If as you say this is low pressure, then a piece of split hose and maybe 2 hose clamps should do the trick.
   / Hydraulic repair help! #12
I've welded a return hydraulic line in a pinch. Set your welder on the lowest setting and use a small rod. 6011 or 6013 will fill better. Use a coat hanger or filler rod and place on the hole like you are TIG welding, then quickly strike the top the filler rod with the arc and back off quickly and repeat as required. Be careful or you can make a bigger hole than you started with.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
