hydraulic stand pipe and diverter block problems
   / hydraulic stand pipe and diverter block problems #1
Spag1
englad
massey ferguson 135
Hi, im very new here and also very new to tractors so my questions may seem simple/basic/stupid?? we all start somewhere i guess! And apologies to lots of incorrect terminolgy.
I have a late 60's Massey Ferguson 135, it has pressure control. I am fitting a loader to the front so attempted to fit a diverter valve. There are 2 tubes, one is stand pipe the other is behind it, it has a dogleg bend in it and is supposed to fit into the tee block attached to the standpipe. I can get the standpipe into the pump on its own, but cannot locate the other tube (pressure control tube???) into the tee block at the same time. It will start to locate but will not push down past the o rings i guess. Iam thinking of removing the whole lift cover and whilst im in there change the o rings on the standpipe etc...
Is there an idiots guide to removing the lift cover, preferably with photos??
Hope you can help
Thanks in advance
   / hydraulic stand pipe and diverter block problems #2
Hope you can help
Thanks in advance
Do a search for a thread by klancf51. I think it was titled "help with Massey 135 standpoint with pressure control". Also a thread servicing the hydraulic standpoint.
   / hydraulic stand pipe and diverter block problems #3
Thanks for the links, I guess I need to work my round the forum and learn to use the serch function...Cheers
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
