Hydraulic Toplink?
/ Hydraulic Toplink? #1
slinger
I have a BX2330 and need to purchase Cat 0 hydraulic toplink, can't seem to find them. Help!!!!! /forums/images/graemlins/confused.gif
/ Hydraulic Toplink? #3
You mean a top link that has 5/8" pin holes right?
Good luck. I don't think you will find any. Use a more common cat 1 link that has 7/8" pin hoses and use reducer bushings. TSC probably sells the bushings.
/ Hydraulic Toplink? #4
After I sent that message I knew I messed up, it's a BX2230, but you knew that? The trouble is that the pin, center to center, closed can only be about 13". I seen one for Cat 0 at a Kubota dealer about a year before I bought this tractor. So I know they are out there, but just can't find them.
/ Hydraulic Toplink? #7
The retracted length of the top link has nothing to due with the category 0 or 1 specification. The category specification deals with pin diameters and spacing between lift pins and top lin pin.
I am sure a BX2230 owner who has purchased a hydraulic toplink will chime in with where they got it. However, don't expect to get an exact match with respect to the retracted length.
/ Hydraulic Toplink? #8
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2010 ALTEC DIGGER DERRICK (A59914)
2010 ALTEC DIGGER...
2021 Kubota RTVX1120 (A64127)
2021 Kubota...
2002 International 9200i Truck (A61307)
2002 International...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
