Hydraulic Trans Strainer Cleaning
   / Hydraulic Trans Strainer Cleaning #11
If the dealer and Kubota do not ask that oil be changed, and I saw little if any dirt on the strainer , then why would one change it ........unless of course you have lots of money and lots of time.
I could also change my tires every two years on my various vehicles , because its safer (and they want to sell more tires) .............but if the tread and side walls are fine , then why would I.
frugal but safe jake
   / Hydraulic Trans Strainer Cleaning #12
At 50 hrs I don't think it is necessary to change the tranny oil in my BX25 just to clean the strainer.
The B3200 owners manual says to just change the hyd and tranny filters at 50 hours not the fluid until 400 hours.
I emailed Kubota Tech support and asked how to change just the filters without getting 5 gallons of fluid in the face. I got an immediate phone call back and the tech told me the manual was wrong and to change the fluid at 50 hours to get any shavings, etc out. He affirmed my question that pulling the filters would dump all the fluid.
I ordered a Work Shop Manual for the B3200 and got it yesterday. While reading the manual it says the same thing.. filters at 50, fluid at 400 so the WSM is wrong too.
   / Hydraulic Trans Strainer Cleaning #13
Over the life time of owning the tractor you are only talking about 1 fluid change difference.
I still can not see why the difference between 49 and 50 fluid changes is so critical.
   / Hydraulic Trans Strainer Cleaning #14
Hi Jim,
My dealer recommended changing the HST fluid along with the filters at 50hrs on my BX. I also pulled and cleaned the screen. I certainly didn't have $75 for SUDT burning a hole in my pocket but it seemed like cheap insurance on a $15,000 tractor. I did also find noticeable amounts of filings/shavings in the old fluid. It was very clean and clear but there were shavings in the drain pan. Good luck.
Matt.
PS: Watch out for the transmission plug gasket. I found mine in the bottom of the drain pan when I was cleaning up:eek: It would have been a lot easier to get it back in BEFORE the new oil was in the trans.
   / Hydraulic Trans Strainer Cleaning #15
So the last item on my BX2660 50 hour is to clean the tran strainer. I wasn't expecting the fluid to keep coming out. I like the idea of a stopper, and replenishing the cup or two lost, rather than draining all 3.1 gallons. Plus, I only have 1 quart right now and plan on seat time this weekend.
....update...
My manual indicates not to change the fluid. The Kubota site has generic info on all tractors and it states to change the fluid at 50. I called a local dealer and they said the 50 hour tran fluid change is the most important one.
Messicks... an order has been placed for 3.5 gallons.
   / Hydraulic Trans Strainer Cleaning #16
I feel better now, went ahead and spent the $90 on fluid and changed the 3.1 gallons. The strainer was very clean, as was the fluid. But now I'm good for many years, or 400 hours.
   / Hydraulic Trans Strainer Cleaning #17
A few of quick points:
a)If were allowed only one oil change, I would pick the 50 hour change because that would eliminate all metal particles
from the manufacturing process and the work-in period. That error in the manual is a rather serious one.
b)I love the vacuum cleaner trick, and I will remember it. However it seems to me that this is not a good time to use it because it seems
like the counter flow created might withdraw some of the metal from the strainer back into the system. I could be wrong, however. Also, the vacuum
runs counter to seal reinforcing pressures, so there is a remote possibility of drawing debris into seal lips.
c)A clean rubber stopper is a much better choice than a rag. It is considered bad technique to use rags on a hydraulic system because
a rag fiber is a huge contaminate relative to the clearances of hydraulic components. It is enough to securely lock up some passive hydraulic
components.
d)I know in advance that the rag comment is a hard pill to swallow. When I catch our maintenance guys doing it, I warn them, but I always get a lot
of eye rolling, and catch all kinds of grief. They do not work for me, so they can through my advice in the trash anytime they choose.
   / Hydraulic Trans Strainer Cleaning #18
Oops..throw my advice, not through my advice.
Sorry, I forgot something quite important about the vacuum cleaner trick: Many vacuum cleaners run the filtered exhaust air through their electric
motor to cool it down. Most of these motors are "universal" motors which means they have brushes which are likely to spark. Therefore, one should
be very careful about using the V.C. trick on anything that could be explosive. I know it sounds silly that I mention this, but it is such a handy
trick, someone could try to over-extend the usefulness of the trick into dangerous territory. I would rather people read my silly comments than any
of us having to read sad and tragic announcements.
Informational Lot - Shipping (A52748)
Informational Lot...
2003 International 4200 Box Truck (A51692)
2003 International...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
