Hydraulic transaxle leak in lawn mower.
   / Hydraulic transaxle leak in lawn mower. #1
turfranger
John Deere 455 diesel
What is the thing to use to stop a leak on a hydraulic transaxle on a lawn mower?
   / Hydraulic transaxle leak in lawn mower. #2
The obvious answer is to replace the leaking seal. After disassembling my Craftsman garden tractor I learned that is not a viable option. There was no way to check fluid level just an opening to add fluid. I drilled a hole just below the seam joining the two halves and installed a hydraulic jack plug. I can now fill from the top until fluid runs out my check hole. I think I got the jack plugs from eBay. My Craftsman uses good old standard transmission gear oil so I just used the heaviest I could find - I think it was 85W-140 or something like that.
   / Hydraulic transaxle leak in lawn mower. #3
Assuming we are talking about the 455 in your avatar. the common leak locations are the O rings on right side for the forward and reverse direction control, And seal for the differential lock rod on left side will slide outward over time and cause a leak. And the third location is the gasket between the transaxle and the hydraulic pump/drive motor on the front of the transaxle. All three require removing the transaxle to get access to the leak locations.
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
