Hydraulic tubing question
   / Hydraulic tubing question
Wow! Turned out to be a busy day. I heard something at the road this morning and it turned out to be the state doing their once every five years or so scraping of the road's edge. So much nice black top soild going into those dump trucks...wonder if I could get some of that... /forums/images/graemlins/smile.gif
Well I ended up giving the drivers $5 per load to dump it at the top of my driveway. I had seen the supervisor and told him I wanted some fill if he could dump it for me, but he did not seem to act on it. I saw a couple trucks go by without looking my way, so I flagged the next one down and talked to the driver...there were three drivers all told and they were happy to put some beer money in their pockets I guess...These were tandem axle dumps, not sure what load they carried but they were full and don't have to worry about scales probably, since they are state vehicles. Kept me away from TBN all day!
Glenn9643
I am going to add flow restrictors I think. It just seems like a good idea.
The reason I am thinking to go with two cylinders on the tilt is because I feel that may make it easier to match the existing design of my 3PH. But even then maybe not. My fixed lift rod is about 17 inches long. The adjustable side goes +/- 3" more or less. So if I could have one tilt cylinder that retracted was 14" pin to pin center, and had a 6 inch stroke, that would be perfect. I don't think this is a common animal.
The next choice would perhaps be two cylinders that had a retracted lenght of 14" and a stroke of 3". By alternating one or the other I could have the same tilt as factory designed, and when both were extended the hitch would be level at the factory designed lift rod length of 17". Something like this may be available.
What I am concerned about is having a tilt cylinder that is too long. I understand it is common to put the adjustable lift rod on the other side opposite the tilt cylinder, and lenghen it to match the mid point of the cylinder stroke. This would perhaps result in being able to apply down pressure when the cylinder is fully extended, as you say, likely not a good thing as the tractor may not be designed to handle this situation.
The leak down you are experiencing my be due to the control valve leaking and not the cylinder. From what I have read here at TBN that is fairly common and is the reason for lock valves being put between the control valve and cylinder.
MadReferee,
My understanding is that those load checks in the Prince control valve only function when the valve is operated, and do nothing to hold the cylinder when the control valve is centered. They are there to hold the cylinder in position when the valve spool is shifted, if the cylinder is under load. At least that is my take on what I have read in the Prince catalog.
Jim at Integration Engineering told me that the tilt cylinders are about 16 inches retracted. This would force the 3PH to run lower if you want to have +/- adjustability with only one cylinder, from what I can see. This may be a non-issue, but it concerns me.
Egon,
Thanks for the info on stainless tube bending. I am not sure if I will need to do it, but it is good to know if I want to it shoud be within my means...if I can afford the fittings!
Inspector507,
Thanks for the link to the picture. I had emailed Jim a while back and go the prices and cylinder lenghts...I am not sure what I will do yet with respect to cylinders. I like the challenge of doing it myself, more than saving money, which doesn't hurt either. But mostly I never did a hydraulic project and want to feel the reward of doing one on my own, kind of thing...
PineRidge,
I will do my best to get restrictors in the lines when I put my system together...I appreciate the advice!
Sorry for clumping all these replies into one post, but it was a busy day. I did not get in until around 9 pm...not complaining though! That pile of soil looks so good I am guite satisfied with the way the day turned out! 6~8 hours seat time did not hurt either... /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif
   / Hydraulic tubing question #12
</font><font color="blue" class="small">( Jim at Integration Engineering told me that the tilt cylinders are about 16 inches retracted. This would force the 3PH to run lower if you want to have +/- adjustability with only one cylinder, from what I can see. This may be a non-issue, but it concerns me.)</font>
Well, my tilt cylinder from Integration Engineering should be here later this week and I should have it installed and plumbed by mid next week. I will keep you updated as to how it adusts and performs.
Thanks Mad,
Hope you can post a pic or two also. Curious about the ends and what the retracted lenght is. That looks like a nice tilt cylinder...look forward to hearing more.
   / Hydraulic tubing question #14
Henro,
Where is near Pgh? I grew up in Monroeville and still have family in the area.
   / Hydraulic tubing question #15
Henro, There are no ends on that one in the picture because different ends are available to accomodate different tractor link styles. You just thread them on.
Mad,
I grew up in Avalon, which is along the Ohio River not too far from the north side of Pgh...now I live just a little further down the river near I79.
Jerry,
I am curious about how the ends compare to stock as far as angles go...
Nice day here...better get out and have some more fun! I can say that because the wife is back visiting her family so there is no danger in being honest at the moment! /forums/images/graemlins/blush.gif
   / Hydraulic tubing question #17
Cool.. It's nice when you can get some good discount material.. and help the other guy out in the process. A total win-win situation, as the county may have been having to pay to dump out that dirt at a C&D landfill anyway... So not only do you have virtually free material, you may have saved the county/taxpayers some money, and the drivers got some lunch or beer money..
Soundguy
MadReferee and all,
Just a quick follow up. I called Prince and was told that they do make a valve with internal pilot operated locks in it. It is stated in their catalog that it is for motor control, but Kevin at Prince said it works with 2-way cylinders, and that they sell them to guys for use with backhoe stabilizers.
That part number is SVL1CA7X
X = 1 thru 7, depending on handle style. This is a work section of the stackable SV series valve.
This is not immediately apparent from what is shown in their catalog schematically, or in verbiage, but it is shown fairly clearly in a cross sectional drawing on page 52, which I was not smart enough to find on my own… /forums/images/graemlins/blush.gif
   / Hydraulic tubing question #19
</font><font color="blue" class="small">( they sell them to guys for use with backhoe stabilizers )</font>
The perfect application for check valves.
Henro,
if you are planning on having a 5 spool valve I hope you have considered size. Right now my 3 spool SV is 8.5" right to left and 8" front to back not counting the lever linkage. Adding 2 more spools increases the right to left measurement by 3" to 11.5". The check valves stick out another 2" or so to make the front to back measurement 10".
That is a monster, not to mention all the work port hoses you will have to deal with.
You will have to mount this thing off the ROPS using a design similar to the TCC and Gearmore setups. Butt ugly in my humble opinion.
You may be over analyzing / over thinking the TNT problem. Maybe KISS should apply here.
<font color="blue"> You may be over analyzing / over thinking the TNT problem. Maybe KISS should apply here. </font>
I am a firm believer in KISS, for sure. /forums/images/graemlins/smile.gif And an optomist too! I don't see it as a problem at all, but rather as an opportunity! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
My version of KISS is to make sure I understand what I am doing and what I need before I start, at least when a $1,000 or so is on the table.
My experience is doing otherwise makes things real complicated when I buy what I did not really need/want...or put something together wrong because I understood wrong.
My rough size approximation was 9 x12 x 5. I have to make a wooden box and see how big that is and where I might put it. I don't think the increase from about 9" to 12" in width is that great, considering the reward is two additional control valves for future use. Potential uses that come to mind are hydraulic tilt (if more was needed over what the 3ph can do)or angle adjustment on a rear blade. "If I add them the implements will be built" kind of thing... /forums/images/graemlins/cool.gif I'm always looking for new welding projects.
I have to sick my imagination on the where-to-mount-it part and see what happens. Who knows, if I do that I might just take the money and run down to see OkeeDon before it gets too hot down there... /forums/images/graemlins/crazy.gif
24635 (A55853)
24635 (A55853)
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2020 Deere 325G (A50123)
2020 Deere 325G...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2002 Ingersoll Rand P185WIR Towable Air Compressor (A55851)
2002 Ingersoll...
