hydraulic valve noise
   / hydraulic valve noise #11
Haybaler9,
No, two singles do not make a double. Air can make noise. It is hard to say with out hearing it. On a single acting cylinder loosen the fitting at the cylinder and operate the valve. It should push out any air.
I do not know which valve you have. It is a fact that some of the valves will not function correctly with single acting cylinders. For simplicity sakes. There are basically two different types of cartridges in the valve. One will allow back flow, ie. a single acting cylinder, and one will not, it acts as a check.
This may not be your problem. It may be as Mad has suggested. It is worth looking into the type of valve you have.
Ron
It's a Prince 4 way valve. I didn't try it with the work ports disconected.
it's a standard old style fisher plow with the original cylinders.
Problem solved. I turned the relief valve adjuster in (up) about 1 1/4 turns and it works great with no noise. Thanks Mad!
1999 CAT TH63 (A53314)
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
MMS MS36C (A53316)
MMS MS36C (A53316)
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
