Hydraulic valve similar to 3-point hitch?
   / Hydraulic valve similar to 3-point hitch? #1
ishiboo
Platinum Member
Oshkosh, WI
Kioti NX6010HSTC, Cat 279c
I am thinking of building a front hitch for my L3650. Not sure if it will be a full 3-point or simply custom at this point.
One thing would be nice would be instead of just using a regular spool valve, having a "level valve" like the 3-point hitch has, so that I can simply move the lever to whatever height I want the hitch at and it would essentially put it there. Obviously this would require the valve being configurable to the cylinder bore/stroke/etc. at the very least, making it a somewhat complicated proposition.
Are there valves out there like this for the general-purpose?
   / Hydraulic valve similar to 3-point hitch? #3
If I'm understanding your question correctly that valve will not perform the function your requesting. You would need a valve that includes some type of position sensing or an electronic system like those on larger tractors seen here. http://www.fronthitch.com/v3/pages/accessories.cfm
I'm not sure a manual valve is available for the application your seeking
   / Hydraulic valve similar to 3-point hitch? #4
This is what he said.
Quote: so that I can simply move the lever to whatever height I want the hitch at
   / Hydraulic valve similar to 3-point hitch? #5
All my stuff is older, so I'm not sure what's typical of newer "cuts", etc - but what I interpreted from the OP's question is that he wants position control.
On both my tractors, this is done internally using some sort of pilot valve and a "finger" that gets moved by the 3ph lever - when the lift is where you placed the lever, no hydraulic oil flows thru the cylinder - if the hitch raised on its own, the pilot valve bleeds off - if the hitch "sags", the pilot valve will raise it til the "finger" and the lift lever agree... Steve
   / Hydraulic valve similar to 3-point hitch? #6
That's a big ten four there Steve. I think J.J. missed the boat on this one.
   / Hydraulic valve similar to 3-point hitch? #7
It's not a who won this thread thing, or a who is smarter thing, I hope.
It's a collective, how can the TBN network help the OP.
Everyone will miss something at some point.
We all do.
   / Hydraulic valve similar to 3-point hitch? #8
So who said anything about winning or losing? I see two opinions on the table I agree with the second one, simple as that. Maybe I missed something.
   / Hydraulic valve similar to 3-point hitch? #9
I think the type valve with position control would have to have some form of feedback rod(manual or electric) built into it to accomplish what you desire.
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
Hay Spear for Tractor (A51573)
Hay Spear for...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
