Hydraulics hose popped off - bleeding question
   / Hydraulics hose popped off - bleeding question #1
monkeybreath
Central California Foothills
Kubota 3410
The fanasty of tractor ownership meeting the realities: One of the hydraulic hoses came out of a connector. I unhooked the hose and will take the fittings and the hose in to town tomorrow to have it reconnected as I do not yet have tools to do this here, or the experience to know just what to do with it. My question - what do I need to do after I reconnect the hose ? I know I will need to add some amount of hydraulic fluid and then perhaps bleed air from the system but I have no idea how much fluid to add or how I go about bleeding the system - assuming that is necessary. I am not sure how this popped out but could have been due to brush and mowing. Shot fluid all over and I shut down. Thanks in advance for any much needed advice you can provide. Assume I have no knowledge re how to do any of this.
   / Hydraulics hose popped off - bleeding question #2
Check your hydraulic oil level and fill it according to your owner's manual. Hook the hose back up, start the tractor and cycle all your hydraulics back and forth a few times. Then re- check your hydraulic oil level and re- fill it according to your owner's manual.
Thank you - sounds like something even I can do. I thought there would be more to it. I am anxious to get back to work.
   / Hydraulics hose popped off - bleeding question #4
Nope that's it. The hydraulics may be a little jerky when you cycle them, but they will smooth out once the air gets out of the lines, etc. Just be sure to check and top off the fluid again once you have sufficiently cycled the hydraulic equipment.
- Gerald
   / Hydraulics hose popped off - bleeding question #5
The nice thing about the way hydraulic systmes are designed today is that they are self bleeding. It's very unusual to find a system where something gets airbound. The systems I have worked with that had that tendency had bleed valves designed right in. /forums/images/graemlins/smile.gif
   / Hydraulics hose popped off - bleeding question #6
I read in a recent post from one of the Yahoo groups that it's a good idea to run some fluid through the new line before connecting the the second end to flush out any debris.
Ford Super Duty FX4 Pickup Truck Bed (A51692)
Ford Super Duty...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
2006 Ford E-350 Passenger Van (A51692)
2006 Ford E-350...
