Hydraulink build?
   / Hydraulink build? #1
puckgrinder85
Platinum Member
WI
'13 Yanmar Lx4100
Anyone copied the "hydraulink" rear top link. Looks just like a double acting cylinder with a valve in the middle to control flow from one end of the piston to the other. Where could I source a ram with the ball/heim type joints that a toplink typically has? That and what kind of valve would be used? Would a needle valve work for such an application? Seems I could make one of these rather easily.
   / Hydraulink build?
Ok, so the ram isnt a big deal, two really short hoses and a valve I'd be in business. What kind of valve should be used? Some kind of needle valve?
   / Hydraulink build? #4
   / Hydraulink build?
This theory is flawed in one severe way, the volume on the rod side is less than on the other side, a simply ram wouldnt work without having something (like air) in the cylinder to help with the volume difference.
   / Hydraulink build? #6
I believe the Hydraulink does have some air in it .
   / Hydraulink build?
Yea, it does, it literally has to have some air in it because the volume differes from one side of the piston to the other. You cant build one that has fluid on both sides, unless you make some sort of accumulator so that extra oil on the open side has room to go.
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
