Hydro-generated Ignition
   / Hydro-generated Ignition #1
stumpfield
Sierra Foothills
2005 MT265B
Anyone familiar with or have a Tankless Water Heater with Hydro-generated Ignition? It sounds perfect for my off-grid location. How reliable is it? A google search found 1 guy complaint about it take 10-15 minutes to start and doesn't work if it's windy outside. Minutes??? that's a lot of water wasted....
   / Hydro-generated Ignition #2
i had to ask google what hydro-generated ignition was....
"The latest development is a hydro-generated ignition system from Bosch, the AquaStar 125HX. It uses the flow of water to turn a miniature turbine that creates an electric spark that lights the pilot"
I could see how it uses some addtional water, but shouldnt be to bad.... if your going to plumb one in, you could always use a recurculator circuit in the plumbing so that you wernt running water down the drain.
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
