Hydro oil change or not at 50 hrs. for DK45SE HST.
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #21
I would suggest that oil temperatures in an elevator system would be greater than in our tractors. I have measured oil temperatures on many elevators and they range from room temperature to 90 degrees celcius. A busy elevator in a medical building could run at the upper range of that for 12 hours straight.
I agree...if there are gears in the system I see the need for hydraulic oil changes but is that the case for non HST tractors?
Well it sounds like the temps could be about the same. Yes all common tractors I know of use the transmission and rear differential as the "tank". Not all have wet brakes, but all or most modern tractors do.
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #22
So on a non HST tractor is the transmission oil separate from the hydraulic oil?
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #23
No they are all one and the same..common sump
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #24
Also, in addition to the wet brakes, my DK has wet clutch packs for the 4WD and PTO, These are similar to the clutch packs in an auto tranny. These all shed friction material over time.
There are probably other differences from elevators.
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #25
Yeah I forgot about those, mine has those too.
   / Hydro oil change or not at 50 hrs. for DK45SE HST. #26
My personal choice has been for the two DK series tractors I have owned since 2009 'till now, with a combined 900+ hours between them, (550 of those hours currently on my DK-40se/hst), to ONLY change the hydraulic filters, at specified intervals. These filters aren't doing their job if the fluid is becoming contaminated to the point of allowing debris of any kind back into the hydraulic fluid as it passes through the filters, IMHO, and BTW, my dealer, who has sold and serviced tractors for over 50 years.
I have a set of all filters for an upcoming change, and may decide to do an oil analysis on the hydraulic oil to see what the lab shows is present.
You must decide what to do based on your comfort level.
Best wishes for a good outcome.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
Food Truck - 1999 Chevrolet Blue Bird School Bus and Turnkey Food Truck Business Package (A55314)
Food Truck - 1999...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
Rooster Weathervane (A55853)
Rooster...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
