Hydrolic fluid vs gear lube in front axle debate
   / Hydrolic fluid vs gear lube in front axle debate #1
Phil1959
Maine
Branson 3510
I have a Branson 3510 read through this site and can see many debates on what to use in the front Axle. The manual says to use Hydrolic fluid. My dealer recommends gear lube. I am going to use hydrolic fluid. I looked at the power steering and it appears to be attached so that the fluid in the front axle also flows through the system. I also notice when I topped off the front axle the level of fluid on the rear indicator increased. Maybe I am wrong but personaly I think it is best to do what the manual says. Any thoughts on this?
   / Hydrolic fluid vs gear lube in front axle debate #2
I'm no expert, I have a ford , but I don't see how the front axle oil can be attached to the "main" hydraulic reservoir.Mine is separate, and have always used the same HYD oil as the tractor. But not the same reservoir.
Hope someone else can comment further.
   / Hydrolic fluid vs gear lube in front axle debate #3
The manual calls for hydraulic fluid.
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
