Hydrolic/hydrostatic transmission whine
   / Hydrolic/hydrostatic transmission whine #1
tdejong302
Munising, MI
New Holland tc18
here is a link to what it sounds like. This isn't my tractor just found it online to simulate whats going on... Tractor runs fine, loader/pto work fine. However when I put my foot on the peddle to go forwards or backwards the hydrostatic whines. Checked fluid and it looks good. Hydro, oil and power steering all good. Look clean and topped off. Does this in 2 and 4 w.d. whines louder as rpms increase. I just bought this tractor used and it worked great. Now this sound just appeared. I was moving snow with the bucket in 4 w.d. in high gear. Not sure if that caused it. Thank you for taking the time to respond and offer suggestions. Tried searching this forum but it doesn't appear to be working. My tractor is a new Holland tc18. 2006.
   / Hydrolic/hydrostatic transmission whine #2
Is the parking brake engaged?
Due to troubleshooting and getting ideas from other places that was one thing I checked. thank you for your reply. And suggestions on links and searching tbn.
   / Hydrolic/hydrostatic transmission whine #4
Most hydrostats make the wining noise when overloaded, and its even louder when cold. Does it make the noise in low? When noise sounds, reduce pedal and see what happens.
   / Hydrolic/hydrostatic transmission whine #5
You've got to always remember, the pedal is not a throttle, like your car, but a link to the hydrostatic transmission. When running in high, don't ever stomp the pedal down like in your car. Instead, ease it down and as speed increases, ease the pedal down further. Working loads, like hauling snow, is best performed in lower ranges, ESPECIALLY if there is any incline whatsoever.
   / Hydrolic/hydrostatic transmission whine #6
The HST will while if you're in too high of a gear for the work you're doing, or if you're depressing the pedal too far for the amount of engine power available. Switch to a lower gear range and/or back off the pedal. Remember the HST pedal is like a gear shift -- the farther you push it, the higher the gearing. It's not a throttle.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A60460)
2012 Vermeer...
Deere 35P (A53317)
Deere 35P (A53317)
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
