hydrolic top link
   / hydrolic top link #61
I believe that a spool type valve that doesn't leak some is an anomaly The only thing that stops any leakage is a "perfect" fit between the steel spool and cast iron or aluminum valve body bore as there are no other internal seals. The problem is that heat expansion affects these materials to a different degree so almost impossible to maintain that "perfect" fit as things heat up. We're talkin' microns on the diameter.
I'm under the impression that most of the newer high end tractors use solenoid or servo operated valves along with soft seat poppets to achieve zero leakage.
   / hydrolic top link #62
I notice most of the drop when I am driving with it elevated. Or if I leave it with tension on it with the tractor off. Normally when I'm using the bush hog there's not much tension on it so I don't notice much of a problem then but there is still some drift. I have a backhoe that I run off of my remotes as well and it will also drift down about the same amount. I'm assuming it's my valves not the cylinder.
Yes, typically it is the valve that leaks. So a question, just how much of a bother is it when you are using an implement, your mower, whatever? I ask because for me, even with how bad my small tractor, rear remote leaks down, it does not affect my working, I'm sure that is why I have not messed with fixing the problem, in reality, so far anyway, it is not a problem worth worrying about.
I'm not trying to say that this is not a problem, it can be a HUGE CONCERN. I have had customers that could not go even a few hundred feet without things getting out of adjustment so bad that work simply could no be accomplished, what is sad is this has been on brand new $35,000 tractors with factory remotes.:shocked:
   / hydrolic top link #63
You are correct, all these spool valves leak, some. It's that some that is the secret. I get asked all the time, why are your valves so much more than so & so's?
My valves are typically anywhere from 2-4 times what people can buy off the internet. I hardly make anything on my valves, so it is not my mark-up. They cost more, because they are simply built with much tighter tolerances than so many of the low cost units that are out there. If the valves that I sell leaked like most of the ones that so many people buy, I simply would not sell them, not worth the trouble.
   / hydrolic top link #64
I didn't know that float wasn't available with check valves. Since I have trailing wheels on my Rake, float is nice to have. And one less function to have to adjust.
   / hydrolic top link #65
The check valves take X amount of pressure from the valve to open. Put the valve in float mode, no pressure. The check valve stays closed and the cylinder is locked in position. Thus check valves equal no float function with said cylinder.
   / hydrolic top link #66
Would it be too much to ask to have valves on the cylinder to enable/disable the check valves?
   / hydrolic top link #67
You might find that option or you could plumb them up yourself.
   / hydrolic top link #68
You can do all kinds of things, how bulky do you want it, how much money do you want to spend?
   / hydrolic top link #69
I once made the mistake of putting a valve from one side of the cylinder to the other, as a float, not realizing the differences in volume.
But it makes me wonder. If one has a mediocre top link cylinder, maybe it would have worked better the other way around, depending on whether your more demanding work requires pushing or pulling on the top link.
   / hydrolic top link #70
Float is very important in some operations. I went to great lengths to get the float on my second remote. It made a huge difference in the operation of my implements as they actually followed the ground, rather than where I last left them. Now I don't have a big operation, but for my hay cutting FLOAT made a difference. Still learning and appreciate any feedback.
BTW I have been around a few years (more than I care to remember), and now more than ever, you pay for what you get, and buyer beware of whom you order from. To me customer service is important. I will pay a bit extra to know the seller is honest. knows what works, and stands behind their equipment. Brian is an example of that. And NO I don't get anything for this comment. He stood by me during one of my Senior Moments :eek::shocked: to make things work. I screwed up in my measurements, and Brian worked with me through my ...... well we have all been there:confused3::ashamed::mur: Not many would do the same.
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
2012 SOUTHERN VAC KILL TRAILER (A53843)
2012 SOUTHERN VAC...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
