Hydrolic/Transmission Fluid lvl
   / Hydrolic/Transmission Fluid lvl #1
TomSr
NW Arkansas
Mitsubishi 2050D
I have a Mitsubishi 2050D. The transmission fluid lvl cannot be seen from the fill plug. I want to change the oil, clean the filter and replace with new oil. Where is the fill lvl how full should it be. My operators manual and repair manual both say to fill to the specified lvl. Isnt that funny. what is that lvl.
That is like my computer telling me to contact the system administrator when thats me. I need help.
Guess I better add a few facts. My tractor has a FEL, so now i need to know what type of oil do i use and again what should the oil lvl be. Manual says 3.5 gallons but that is without FEL.
   / Hydrolic/Transmission Fluid lvl #2
Welcome to TBN. I used the above search link and found an old thread that gives us the answer. There is a plug on the left side of the transmission/rear end case near the clutch that looks like a bolt head with no purpose. Remove this plug when you are refilling. When oil starts to run out, you are done.
Thanks, I tried searching old post and found a lot of useful information but not that. That tells me what i need to know also found and old post that tells me what fluid to use.
I appreciate the help.
   / Hydrolic/Transmission Fluid lvl #4
Actually, the level plug on your tractor is on the right hand side of the transmission behind and about the level of the foot rest. Drain the transmission and clean your filter. Refill with a quality tractor hydraulic oil such as John Deere type 303. If you have questions about service, email or call us at 1-800-609-5110. Bill -satohparts.com
   / Hydrolic/Transmission Fluid lvl #5
Thanks for straightening that up Bill. I guess the old thread was wrong unless I read it wrong. I think my fill plugs on my S-470 and the Mitsu 1450 are on the right also.
   / Hydrolic/Transmission Fluid lvl #6
The level plug on your S470 is on the left side just in front of the bend in the hydraulic line. I have the same tractor. Bill
   / Hydrolic/Transmission Fluid lvl #7
Now I really feel stupid. I've changed the oil several time in both tractors before I found out there was a fill level plug. That Buck is a tough one. Do you have any Buck parts tractors? I may break down and buy some tin one day. Mine's been rolled three different times. (not by me)
Knight 1040 Manure Spreader (A50774)
Knight 1040 Manure...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
