Hydrolic Valves Open Center
   / Hydrolic Valves Open Center
biggerten said:
I have an LW-7 back hoe, and have it powered by a Prince 7A pump, same pump as yours, lower flow rate (7 gpm). Works fine, valves are open center.
Glad to hear that you have no problem with the LW-7 back hoe. I also just bought a small 7 GPM pump and will try to sell my 21 GPM on eBay. I hope with this setup the backhoe will finally work.
By the way, I also want to use this pump also for the log splitter.
:confused: Can any one tell me what size oil reservoir I should purchase ?
   / Hydrolic Valves Open Center #32
Good luck with the new pump...
As a general rule of thumb, you should have a tank the same size as the pump is rated for.
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2018 FORD F-150 (A52472)
2018 FORD F-150...
Informational Lot - Shipping (A53472)
Informational Lot...
2008 Chev Impala (A51694)
2008 Chev Impala...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
