CoveyBruce
Hey all,
I'm having some problems with my New Holland TC35D tractor. So you know what I've done with it and what's going on I'll tell the whole story
About a week ago I noticed that diesel was leaking from around the injector pumps on the engine. I thought nothing of it and ordered new seals for all the IP's. (100 bucks for 9 seals!)
Anyways a couple days ago I received the seals, so I went out to get the tractor and bring it up to the shop so I could work on it and get them replaced. Well what do you know, it doesn't start, wont turn over but the starter's still engaging and trying to turn it.
My first thought was that it had seized up or some water had gotten in it and rusted it, so I took a pipe wrench to it. I got it to move about a 1/4 of a turn but that was it. (I'm hoping that this wasn't a big mistake)
Well, when that didn't work I decided I better start taking it apart. The first thing I started to take off was the exhaust outlet on the side of the engine, I knew something was wrong when it started to leak diesel, and when I took it off out came a cup or two of it.
I did some research and found out that it was probably hydrolocked with diesel. By now I had already taking off the cover to the valve arms, the air inlet, exhaust, and injector pump assembly.
So next I took out the injectors and tried the engine. Diesel shot out ten feet, literally.
So after turning it over plenty to get all the diesel out of it, and replacing the oil, I put everything back together.
Also in all of this I replaced the seals in the injector pumps. I'm hoping that these seals were the culprit for all that diesel.
So I got everything back together and tried to start it. It starts, but there's a loud knocking sound coming from the engine. After doing some more research, I learn that this might just be something with the injectors, so I take them all out and clean them again. Now the knocking is much quieter, but it's still there, and it gets louder when I turn up the throttle. It's also blowing a light blue smoke out the exhaust.
I've heard that his might mean that it needs new injectors, or maybe the the timing for the injector pumps is off. Could I have messed something up when I replaced the seals? I only took out what I needed to get to the seals, nothing extra.
Or could it be that I bent the piston rods by trying to turn it with a wrench?
Also do you think that the bad seals in the injector pumps are what caused the problem in the first place?
What do you guys think?
Did I explain everything enough?
Thanks in advance! Stuart
