aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I merged the two threads.
Aaron Z
Aaron Z
Mine is at 3000 hrs with the original injectors. I did have the pump rebuilt, but it was for o-rings leaking externally.
I know that it will make a bunch of racket on restart if it runs out of fuel. It takes a few minutes at idle to straighten itself out.
Ok, I'll do that.
Is there anything I can do to see if it's with the pump or not? I'm worried I might have done something when I changed out the o-rings in it.
One thing i'd like to know is if it's okay to run the tractor for extended time? Will it ruin anything?
I don't think I would be using the tractor until I found out what the "Knock" noise is. If I remember correctly you also said you had tried to start the tractor with the starter and the starter would not spin the motor, you then confirmed the motor was "Hydro Locked" by using a large pipe wrench. My guess is that you have bent a rod.
