Hydrostat pedals
   / Hydrostat pedals #21
MossRoad said:
Now I'm confused... do some HST units have a clutch for something? :confused:
Yup, mine does. I need it for starting, changing ranges, engaging either PTO and if ever need be - towing.
How do these other HST's work without a clutch? How do you know for sure that nothing is engaged. If that JD breaks down on a paved drive/road and you need to pull it aside to safety or onto a trailer, how do you put it in nuetral. That electronic switch is not going to work if the tractor is not running. Here comes the "My JD never breaks down" posts. :rolleyes:
   / Hydrostat pedals #22
My JD has a "N" in the selector range. I would assume you would select neutral and it would roll.
   / Hydrostat pedals #23
Is this selector range the electronic part you mentioned. If it is electronically controlled, it's not going to work when the tractor is off or has a dead battery.
   / Hydrostat pedals #24
I'm not Tact but I can answer. The neutral is a mechanical neutral just like range A,B and C. Stop, select range with lever and go. No clutch needed. Neutral is true neutral.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
Towable Orchard Sprayer (A55851)
Towable Orchard...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
