Hydrostatic drive only goes one direction. No reverse
   / Hydrostatic drive only goes one direction. No reverse #1
Cephas71
Caterpillar D5K2 LGP 2012
Hoping someone out there has experienced and fixed this problem on my d5k2
   / Hydrostatic drive only goes one direction. No reverse #2
I would start by exposing and inspecting your linkage and seeing if there's a linkage reason why your variable pump wobble plate is not going over center. If it is going over center into the reverse and you're not moving I would think the issue is internal in your hydrostat
   / Hydrostatic drive only goes one direction. No reverse #3
Cephas in your other thread you posted today you say your angle blade only turns in one direction. Assuming it's the same piece of equipment and blade only angles one way and tractor only moved one direction? Seems like an issue with hydraulic flow...is there more to the story? Like everything was normal until I hooked up this blade? Did both these things start at the same time?
2025 Wolverine BC-13-72W UNUSED 72in Brush Cutter (A47484)
2025 Wolverine...
2010 Ford F-150 Ext. Cab RKI Service Truck (A45336)
2010 Ford F-150...
2009 Utility Trailer 53FT Dry Van Cargo Trailer (A44571)
2009 Utility...
2025 Icon G617.2+2G Gas Powered Golf Cart (A44572)
2025 Icon...
2012 4in Double Diaphragm Towable S/A Water Pump (A44571)
2012 4in Double...
2022 KUBOTA MX5400 HST TRACTOR (A43005)
2022 KUBOTA MX5400...
