Hydrostatic drive slow to respond on cold start-up.
   / Hydrostatic drive slow to respond on cold start-up. #1
cspieg
Kioti CK30
I have a 2005 CK30 with loader and have had a chronic problem with the hydrostatic drive upon start-up when cold. The drive will not engage immediately but working the peddle will eventually cause it to engage with a grinding noise. Once engaged and warmed up the drive works fine. I have noticed that if I work the front end loader, steering wheel, and 3 pt hitch, the drive works almost immediately. Any thoughts would be greatly appreciated.
   / Hydrostatic drive slow to respond on cold start-up. #2
Have you changed the fluid&filter(s),check manual to make sure you use the proper fluids.
   / Hydrostatic drive slow to respond on cold start-up. #3
I'd change the fluid & filters then refill with a good synthetic fluid.
   / Hydrostatic drive slow to respond on cold start-up. #4
There may be a mesh screen in the return line that is clogged too. Best thing is to change the fluid, filters and clean the screen. Clean the pan and inspect the fluid for metallic flecks. I would ask the dealer (or read the manual) to determine the correct fluid for your climate.
Is there any chance that the wrong fluid was added to the hydro system sump? I've heard of this when a well intentioned but poorly informed person has added gear oil to a hydro. The thick fluid can cause cavitation and that means permanent damage to the pump.
   / Hydrostatic drive slow to respond on cold start-up. #5
My 2011 CK 30 does the same thing. If I press the pedal as soon as it's running, I usually don't get anything. If I wait 10-15 secs, all is fine. I've never really considered this an issue, but I'll mention it to the dealer and see what he says.
   / Hydrostatic drive slow to respond on cold start-up. #6
My used 2006 CK30 does the exact same thing. I bought it in 2008 with 300 hrs on it, the dealer changed fluids and filters just before delivery.
   / Hydrostatic drive slow to respond on cold start-up. #7
Pretty typical for cold non-synthetic oil. Let it warm up a couple minutes, or go to a different oil.
   / Hydrostatic drive slow to respond on cold start-up. #8
Even in hot weather I have alway let my CK35 HST warm up for a minute or two. In cold weather I will let it run for a few minutes before using it, think that's the right thing to do. I have, out of curiosity, tried the HST right after starting it and it doesn't really want to move, that's why I warm it up so it works right, hate to think I could damage something trying to run it cold. As a bonus it gives me time to give the tractor a quick look over to make sure it is all there :laughing:. :)
   / Hydrostatic drive slow to respond on cold start-up. #9
Doesn't matter what temp. it is outside, I warm the tractor up a few minutes before moving it (~5 if it's warm out or 10+ minutes for <40*) Does this happen if you've been working with the tractor and it's all warmed up or just the first start of the day?
   / Hydrostatic drive slow to respond on cold start-up. #10
Guys, read the freaking manual. You are always supposed to let these things warm up for a certain amount of time based on outside temp. It's not so much the temperature as it is fluid pressures accumulating in the drive sections of the HST trans. This isn't a Honda civic, you need to give the juices a minute to start flowing.
   / Hydrostatic drive slow to respond on cold start-up. #11
You are right Highbeam, got out my manual and copied it. guess it's a good thing I'm always giving it a few minutes to warm up. ;) :)
  • Warmup.pdf
   / Hydrostatic drive slow to respond on cold start-up. #12
For the first two years of ownership, my Kioti ck30 HST would operate promptly and quietly after a few minutes of warm-up.
NOW, at about 42 months, it takes many minutes for the hydro to want to move the tractor no matter the temperature outside.
Some of the above descriptions suggest this may be normal. Am I understanding these comments correctly? For comparison, I have a Mitsubishi built Mahindra and it it very quick to engage the Hydro even in very cold temps.
   / Hydrostatic drive slow to respond on cold start-up. #13
When was your most recent hydraulic oil and filter change?
   / Hydrostatic drive slow to respond on cold start-up. #14
I'm embarrassed to admit that the Kioti only has 30 hours on it. Therefore it has not had a hydraulic oil / filter change yet.
Not long after I bought the tractor my job took me out of town for months at a time. This pattern continued until this past October. On my short visits home only rarely did I use this tractor. For the few chores around the house I used our little Mahindra.
   / Hydrostatic drive slow to respond on cold start-up. #15
Then your tractor's performance is normal for one in that state of neglect.
   / Hydrostatic drive slow to respond on cold start-up. #16
Thanks "Super" for the well informed, insightful, helpful response.
   / Hydrostatic drive slow to respond on cold start-up. #17
It was exactly that IF you don't think a filter change at a minimum and ideally a filter and oil change won't help your concerns. You have a 4 year accumulation of condensation and other contaminants in your hydraulic system.
OR, if you just want to complain about your "new" tractor, that's fine, too.
   / Hydrostatic drive slow to respond on cold start-up. #18
My initial inquiry was a request for guidance and/or specific suggestions.
Other, earlier posters had suggested that what I'm observing with this tractor may be normal. I'm looking for some additional confirmation of that or Kioti specific direction. Perhaps it is best that I request responses just from owners of similar model Kioti tractors.
I'm not complaining about my tractor. I know it to be a fine machine.
Again "Super", thanks for taking a shot at it.
   / Hydrostatic drive slow to respond on cold start-up. #19
Forget all the drama and change the hydraulic filter, see if that improves the operation. I would look for water in the oil and I would cut open this filter to see what is in it if anything. I would recommend getting the whole tractor warmed up and run it for a few hours under load. More frequent use would be better for the tractor overall.
   / Hydrostatic drive slow to respond on cold start-up. #20
Hydraulics are affected by temperature and from what I heard from the pipeline guys in Alaska extreme temps often meant equipment was kept running for days/weeks/months at a time.
There is often a cold weather synthetic fluid with a broader operating spectrum but it costs more.
The foreman at the dealership where I bought my tractor said I was doing my tractor a favor by letting it warm up a little before making it work in cold temperature.
With few hours over the length of ownership it could very well have some moisture in a system that seldom gets hot enough to get rid of any.
I was worried at just how hot my fluid would get working all day with temps around 95...
Not a bad idea to check the strainer/replace the filter just to eliminate that possibility...
What does the manual say about change interval and fluid selection?
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
SAMSUNG STEAM VRT WASHER & SAMSUNG MOISTURE SENSOR (A60432)
SAMSUNG STEAM VRT...
2394 (A60432)
2394 (A60432)
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2017 Chevrolet Tahoe SUV (A59231)
2017 Chevrolet...
