ozzie tractor
if the neutral is intermittent, the one thing i can think of which causes this is the cam for the neutral is loose on the trans control shaft. check the clamp bolt is tight (take a torch) and try to see if there is any movement, this will make the neutral move about and you cant adjust it with the adjuster egon mentioned (10mm bolt into a BIG bolt with slot in it, loosen 10mm and turn big bolt with screw driver, have wheels jacked up and engine running fast, 1/8 turn make a huge diffrence)
