HyGuard J20C Trans fluid
   / HyGuard J20C Trans fluid
Are you sure it is High Viscosity Hy-Gard?
Yeah, the manual says "John Deere High Viscosity Hy-Gard (J20C)..... Do not mix oils. Do not use type F automatics transmission fluid, J20D Low Viscosity Hy-Gard, or Bio Hy-Gard".
   / HyGuard J20C Trans fluid #12
I just went out to the garage and looked at the one gallon (TY6354) container label, and it doesn't say anywhere it is High Viscosity oil. Just Transmission and Hydraulic Oil. I have JD345 tractor that runs with TY22035 Low Viscosity Hy-Gard oil. Two different types.
   / HyGuard J20C Trans fluid #13
I use John Deere Hy-Gard oil in John Deere Equipment and the Kubota Super hydraulic fluid in Kubota equipment.
That is my equipment though. I am a firm believer that if a person wants to use, used motor oil in their own equipment, let them do so.
   / HyGuard J20C Trans fluid #15
I'm sure we all know that John Deere "doesn't" own a oil refinery, and has no faculty to make their own oils. John Deere may say they engineer their own oils and have a refinery to make it by their specs. Given that may be a fact, they still have someone to make the oils and chances are it may be a brand that is sold over the counter in some automobile stores or elsewhere. It turns out to be same as 10-W-30 oil
Hy-Gard oil can be used in most transmission and hydraulic
applications calling for 10W-30 or 5W-30 engine oil.
NOTE: Hy-Gard should be used in all applications calling
for JDM J20C.
–– Low-Viscosity Hy-Gard should be used in all applications
calling for JDM J20D.
–– Low-Viscosity Hy-Gard and Hy-Gard are compatible with
JDM J21A hydrostatic fluid and can be added to systems that
contain hydrostatic fluid.
   / HyGuard J20C Trans fluid #16
Mo Lad
You don't have a clue what JD does in their oil labs. And should look into the companies that they do own... 'nuff said.
   / HyGuard J20C Trans fluid #17
Well you certainly can't go wrong by following what the owner's manual specifies. :thumbsup:
   / HyGuard J20C Trans fluid #18
Are you sure it is High Viscosity Hy-Gard? I have a CUT and have had larger JD garden tractors for decades and they all call for Lo-Vis.
The Z930A operator's manual is pretty clear about the oil:
NOTE: Tractor is filled with John Deere Hy-Gard (J20C) transmission oil at the factory.
Do not mix oils.
Do not use type "F"automatic transmission fluid, J20D Low Viscosity Hy-Gard or Bio Hy-Gard.
   / HyGuard J20C Trans fluid #19
I was going back and forth, regular hygard or lo vis, because the owners manual says it would use either, depending on the temperature, and because I heard of problems going to regular hygard. The JD service guy said to us regular. I was going to check the oil level on my JD CUT and noticed on the dipstick engraved, "Lo Vis Hy Gard." So O stuck with what was in already.
   / HyGuard J20C Trans fluid #20
That is correct. The "normal viscosity" Hy-Gard is just labelled "Hy-Gard".
Mobile Toilet With Shower (A55758)
Mobile Toilet With...
New Wolverine Mini Skidloader Post Hole Digger (A50775)
New Wolverine Mini...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A55788)
2014 Dodge Ram...
Quick Coupler (A53316)
23222 (A50323)
23222 (A50323)
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
