SCUTs and CUTs are price sensitive. Gear pumps are cheap. Gear pumps have a fixed output. If it is a 20 gpm pump, it is pumping 20 gpm continuously. Most of the time it is circulating through valves, oil cooler, and back to tank. Move a valve to a cylinder that requires 1 gpm at 2,000 psi to extend, and all 20 gpm produced by the pump will be at 2,000 gpm. When you shift that valve the hydraulic system suddenly uses 23 horsepower.
In a closed center system there will generally be an expensive piston pump that will be pumping almost no oil at standby (using no power). Shift the valve to give 1 gpm flow at 2,000 psi and the pump will stroke to supply that flow at that pressure. The hydraulic system will use 1.2 horsepower.
Ironic that the small tractors that have low power use an inefficient hydraulic system that wastes power while the large ag tractors with high power capability use the much more efficient closed center systems, but its a matter of what the consumer will pay.
SCUTs and CUTs - consideration in comparing specs - a larger hydraulic pump will absorb more power when a hydraulic function is used leaving less available for the tractor itself. Its a balancing act.
There are other considerations. Gear pumps tend to be less sensitive to contamination so filtration does not need to be as stringent. In the case of a hydrostatic tractor (I am familiar with JD and Kubota) there is generally a hydraulic filter for the gear pump and a finer hydrostatic filter. The hydro transmission like a Kubota Grand L is a closed center system. The oil going into the piston pump has much finer filtration and consequently, the filter costs much more than the similar sized hydraulic system filter.
