Sprayer I can't attach sprayer, paint on the bar.
   / I can't attach sprayer, paint on the bar. #1
AlabamaFarmer
Minooka, Alabama
MF 1533 4WD
I can\'t attach sprayer, paint on the bar.
I can't get the 3 pt hitch hooked up. I think its because of paint on the sprayer connection points ( I don't know that they are called). I'm going to sand them down and and grease them up and see how that works. Any other suggestions>
   / I can't attach sprayer, paint on the bar. #2
Re: I can\'t attach sprayer, paint on the bar.
The attachment pins won't go thru the lower lift arm ball sockets ?
Ben
   / I can't attach sprayer, paint on the bar. #3
Lift pins usually aren't painted, but I guess it can happen. Mine would tolerate a coat or 2 of paint and still slip on, but maybe all your stuff is new. Try some lacquer thinner and a Scotchbrite pad. Most paint will krinkle up and come right off.
   / I can't attach sprayer, paint on the bar. #4
The bulk of what sprayers I have seen have welded "round stock" for lower hitch pins. Some were a little "mushroomed" on the ends, and needed cleaning up with a file.
   / I can't attach sprayer, paint on the bar. #5
My new sprayer had the same problem. Painted pins that go through the balls on the 3pt, too big. Took a metal file and filed off the paint, a little grease and no problem, went through easy.
I stripped the paint, filed the ends and greased the hitch balls and pins. I still can't get it on. I guess ti's going to take a lot more filing. I'm kind of worried about messing them up. Would the quick attach pins help? I'm thinkint about getting some anyway.
   / I can't attach sprayer, paint on the bar. #7
Just curious but do your lower lift arms move freely from side to side? Have you loosened the turnbuckles or pulled the sway pins before trying to attach the sprayer? I have never seen pins that wouldn't mate to the sockets if they are the same category.
   / I can't attach sprayer, paint on the bar. #8
What kind of tractor do you have? Is it a CAT.0 three point hitch, or CAT.I????
Is the pin even CLOSE to fitting?
It's close. I hooked it up with the hitch half on and checked it out. I have a MF 1533. SWEET!!!! My wife doesn't understand why I get so excited about a tractor!
   / I can't attach sprayer, paint on the bar. #10
My FIMCO sprayer came the same way. One side went on, one side had to be beet on /forums/images/graemlins/mad.gif.
Took the angle grinder with a purl max disc and knocked down the paint, cleaned the ends up /forums/images/graemlins/smile.gif. No problems. Good luck!
Ford 8510 (A53317)
Ford 8510 (A53317)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
