I folded my Quick Tach plate
   / I folded my Quick Tach plate #11
I would go as far as saying that design could be dangerous.
Especially if you are under the attachment being held by the ssqa plate....................:laughing:
   / I folded my Quick Tach plate #12
Or it drops it's load and attachment in front of you on the road at speed.
   / I folded my Quick Tach plate #14
I agree it's a sub par design.
It's not uncommon to see them that aren't integrated side to side. But they are built much, much stronger on each independent side.
   / I folded my Quick Tach plate #15
The SS quick attach is NOT a great nor robust design to start with but it certainly requires that it's individual componants remain intact. There is no redundancy.
   / I folded my Quick Tach plate #16
Agree.
My JD 5055e had a 1 inch (approx.) rod running side to side which could rotate. It depended entirely on the attachment to maintain alignment.
No issues
   / I folded my Quick Tach plate #17
Agree.
No issues
Using yours as an example, look how close the top angle bracket of the hitch is to your cylinder pins. Go back and look at the OP's. No comparison.
   / I folded my Quick Tach plate #18
If one side of the QA could operate independantly of the other, I would lose my mind, as I do on my JD 640 loader that does that. As it is, in uneven terrain, I have trouble attaching a ridged side to side SS coupler and it always amazes me how it can be that hard. You would think if you get one side in, the other side not quite engaged and lift up, it should all line up. But it doesn't.
   / I folded my Quick Tach plate #19
I'm betting I could bent a loader arm before my SSQA would ever bend or twist
   / I folded my Quick Tach plate #20
The OP's system cannot operate independently. That's not even an issue in it's design. The issue is the vertical distance from the top angled bracket down to the cylinder pins. Go back and look at the first pic again.
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2025 JMR 78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 78in Dual...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
