I hate grease zerks
   / I hate grease zerks #21
I'm pretty sure the threads on the zerk were 1/8" NPT. If not, they are now. I chased out the threads with a tap, cleaned the zerk with a dental pick, and put it back in. Works great now.
Thanks for the tip on the heat- I should have tried that. A good parts washer would have been handy too.
I considered doing the grooves in the pins- I've seen pictures of that here, but decided it was not yet worth it.
I was able to loosen up the end of my unit, but I had to put the fill tube in a vice to hold it strong enough to loosen the end piece. I think I probably torqued it down too much when I installed the fill tube on the body.
   / I hate grease zerks #22
Grease? Grease gun? Zerk? Huh? :confused:
   / I hate grease zerks #23
Another trick is to have as much pressure off the pin as possible. Try resting the loader on the ground or if it is say a bucket pin try tilting it in different positions. The pin has a hole in it that channels the grease to the wear points, if there is pressure on the holes it is harder for the grease to travel through them.
JJ
   / I hate grease zerks #24
I've got el-cheapo grease guns...no adjustable tips (tried to twist em today... and no dice) ....and problems getting the gun off the zerks at times too. I just couldn't get myself to pay the price for a good grease gun on the last buy. I think I'm about to splurge on a new Lincoln or at least a Lincoln tip. ;)
Penny wise and pound foolish....as many have said. :(
   / I hate grease zerks #25
JJ
Another good tip and something I hadn't thought about-thanks;)
   / I hate grease zerks #26
Check out the grease fitting section in the McMaster-Carr catalog. A wealth of information about grease fittings!
   / I hate grease zerks #27
I had a heck of a time getting the gun off the grease fittings when I first got my Kubota (actually started a thread on it). The solution turned out to be very simple.
The head on the grease gun I was using had four(4) leaf springs that grabbed the grease fittings. I replaced that head with one I bought from a local auto parts store that only had three (3) leaf springs. Problem solved.
Mind you, I did not buy the new head thinking great, it only has three (3) leaf springs. But after trying it out, finding out that it works well, and comparing it to the other head, I am convinced that it why it is not getting 'locked onto' the zirk.
   / I hate grease zerks #28
What a timely read for me! I have been lurking around, absorbing wisdom and thought that zerks were no big deal, couldn't figure out why they cause so much trouble. That is, until I went to grease up my FEL yesterday. :rolleyes: One of the bucket fittings wouldn't take grease. THEN the tip got stuck on it......THEN I pulled the zerk out of the pin when I tried to get it off. The other 15 were all fine. Wierd thing is, the threads were not damaged??? The loader only has around 40 hours on it, I suppose that fitting could have been loose since i got it.
Anway, I took out another to compare to it, it was the same, no messed up threads on the 1st one after all, so I put the 2nd back in the 1st hole, tightened in just fine. I fiddled with the first one with some penetrating oil and a pick and finally got it freed up. Shot some grease through, put it back in the 2nd pin and all is good.
Just thought I would share and say, "My name is Joel, and I hate zerks too!" (Hi Joel)
Hi Joel.
I'm glad you had a better time of it than I did when I broke my zerk :) No more though once I learned the trick here of losing up the tip.
2013John Deere 244J (A47477)
2013John Deere...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
MISC WRENCHES (A53843)
2013 John Deere 824K Wheel Loader (A53473)
2013 John Deere...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
