JC-jetro
Elite Member
so are you saying the 2 brass parts laying on the red O is the main jet and the bottom piece is threaded and can be removed with a screw driver if there is enough room( there is), then the longer piece falls free? Then you clean the 2 tiny holes with a piece of copper wire. This cleans the main jets?:confused2: I do have a mechanical fuel pump that workes off the cam shaft with a pushrod. I replaced it 2 seasons back, I guess it could have went bad again but the last time it was leaking fuel from a vent. It is not leaking now.
Yers Ray, you are correct. Now what you see is Honda carb and I'm not sure if you have the second metering tube in there or not. Concept is the same. If you look at the 3rd picture you see two holes, the one on the side is where needle valve along with the float closes or opens fuel flow in to the bowl. The hole in the middle is the main jet. You might have just the jet as I have on my other small engines. if you do not have enough room down below it , then you might use a stubby short screwdriver. unscrew it counter clockwise and clean it. I would also put the small dia tube on the carb cleaner can and shoot carb cleaner thru the hole to clean it up if you have some varnish there. if you do not put gas stabilizer in the fuel over winter storage can cause issue with the carb.
JC,
