I have a New Holland Ford 535
   / I have a New Holland Ford 535 #1
Tony1961
It has a Oil Leak on the Left side at the Brake rod. How hard it to repair and How would I go about fixing the problem.
   / I have a New Holland Ford 535 #2
If it's where the rod goes into the rearend, all you need is a new boot. Then jack up that side to keep the oil from running out. Then unscrew the rod assy to allow you to pop out the old boot and install the new.
Yes it is. How do you get the Rubber boot on the rod .Do you have take the rod off at the rearend or do you have to put it on front.
Please explain.
Thank you
   / I have a New Holland Ford 535 #4
It's been a long time since I did one, but you will have to take the rod apart. If I remember right you will be left with a short bit of rod sticking out of the housing. Pry out the old boot, slide it off the rod, clean up the shaft and slide the new one on. FYI jack up the side you're doing or you will get plenty of hydraulic fluid leaking out the hole.
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2011 DRAGON...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
