I have a problem with my 455 Deere mower.
   / I have a problem with my 455 Deere mower. #11
Not really a surprise, I have had to clear mice nests from a few tractors sitting around in a shed over the winter. The worst ones are after you start the mower and a mouse was still in the nest.......enough said.
   / I have a problem with my 455 Deere mower. #12
You better get a rat trap instead of your gun. If you don't keep him out he will chew up your electrical wires and you will have a lot more problems. Maybe your battery positive is already chewed and shorted aginst the frame to cause the first problem. Better check the battery cables. I say this because I had a pack rat eat the insulation off my positive cable. I had to tape it up but didn't have to replace it.:confused2:
You also might have hit a hidden obstruction to shake the battery loose then it grounded the cable and died. Do you hace barb wire laying in the mower path or a pipe or big rock?
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
UNUSED FUTURE MINI SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE MINI...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
10' Feed Bunk (A50515)
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
