DaveOmak
Platinum Member
Soot, I recently replaced the distributor cap on my '53 NAA.
On the 8N, is there an O-ring seal on the dist? There is on the NAA.
The replacement cap would not fit on the dist. properly. I found the original cap had a beveled edge on the bottom of the cap to aid the cap sliding over the o-ring. I had to use a dremel and a sanding drum to bevel the edge on the new cap. A little silicone grease on the o-ring and the cap and the cap then seated properly. Of course I broke a rotor when the cap wasn't seated properly but it was a lesson learned.
If you removed the dist. from the engine, you might check to see if it's firing near top dead center on a commpression stroke. Good luck Dave
