I-Match or Pat's Quick Change?
   / I-Match or Pat's Quick Change? #11
Re: I-Match or Pat\'s Quick Change?
I concur with Jeff's post, I match works perfect with JD implements, not so perfect with others. My dealer had to exchange my Imatch prior to delivery with the Speedco version, the I match wouldn't work with the Sovema 64" tiller I also purchased from him. The Speedco (TSC?) has an adjustable top hook, as opposed to the fixed Imatch hook. Despite that boring explanation... the quick hitch concept is the only way to go!!
   / I-Match or Pat's Quick Change? #12
MichMan
I have Pats on my 2210. It works as advertised although I would like something less fiddling. I find myself postioning the tractor then getting off and fiddling with the lower link placement, then backing up some more, etc. The weight box is easy because I have it on wheels and can roll it around. It is diffinitely better than having nothing but some day I will buy a quick hitch and give that a try.
   / I-Match or Pat's Quick Change? #13
</font><font color="blue" class="small">( ....The two mods I made to 'non-conforming' attachments so they would fit the iMatch were neither difficult nor major.... and it was usually just a simple 'cut or torch' off, and 'add or weld' on the pin location at the top (where the top link attached) for the quick attach hook to line up.)</font>
Those "cut, torch, add, weld" jobs may not seem "major" to you, but for some of us, they are. I have a welder, but little experience. I'm not inclined to start welding on brand new implements where a mistake could be costly and/or lead to the destruction of the implement or worse.
</font><font color="blue" class="small">( The iMatch is standare SAE specs, but for many attachments made, they were not figuring on the eventual top hook of the iMatch type equipment (made by other mfg's such as SpeeCo as well as Deere).
Sorry Jeff. Don't like to disagree with TBN'rs, but felt a need here. The implication was the iMatch was non-standard. Just the opposite is true. )</font>
The iMatch ASAE standard has not been widely adopted by many implement manufacturers. That is what I stated and that has been my experience. Look at Keen Kutter, Five Point, etc. and in most cases, the top link will not have the two positions necessary for both QH and normal 3pt hook up. It may be adopted in the next few years, but I am buying implements now, not 2 years from now. I thought the iMatch would be great, and on my JD and Frontier implements, it was nice. But the tenth time I took the hitch off to mount something, I decided it wasn't worth the hassle.
EDIT: Addition --
I also should mention that I had a devil of a time getting bushings for my implements. My JD dealer didn't stock them, nor did the other one in town and there's not a TSC in Springfield. Of the 5 or 6 different farm supply stores in town, nobody had what I needed. The bushings that come with the iMatch don't fit the Frontier Box Blade correctly. My point to MichMan is that you can spend as much time modifying implements and chasing down parts as you save by having the quick hitch.
   / I-Match or Pat's Quick Change? #14
I have expereinced some of the issues you had with your IMatch while helping my neighbor with his. We finally traded it off for the SpeeCo (www.speeco.com). I honestly wouldn't have a tractor without one anymore, takes most of the hassle out of hooking up.
Mike in Joplin
   / I-Match or Pat's Quick Change? #15
I have the Speeco QH. I love it. I originally bought it because it was cheaper than the I-Match (at least in my area) I found an advantage, though in the adjustable top hook. I don't move it because that requires wrenches, but I did try it in different locations to see which worked best for all my implements. I ended up only having to modify my carry all. So possibly the Speeco gives you more options? Jason
   / I-Match or Pat's Quick Change? #16
MichMan,
I'm a SpeeCo fan. You just know that adjustable top hook is gonna come in handy some day. I found my quick hitch at Fleet Farm, it was only $150 and came with a set of bushings. It fit my Five Point brand rear blade perfectly the first time I tried it, and works on the ballast box too.
I haven't read anyone mentioning this yet, but a big reason I got the quick hitch over Pat's was so my wife could hook and remove the implements. Having them on can sometimes be unwieldy, and her being able to take them off doubles my workforce around here. /forums/images/graemlins/laugh.gif
If you're looking at implements for a quick hitch, just know your dimensions and make sure it's got a wide enough attachment point on top for the hook. I'm not sure about the imatch, but the SpeeCo also comes with a link for the top in case you already own an implement where the top hook won't fit.
   / I-Match or Pat's Quick Change? #17
I got tired of the blots on the top pin, changed them out for the long pins with clips, works great. Most folks wouldn't have to do this if your implement are fairly standard, my Sovema tiller is the only oddball.
3320, 300CX, Box blade, 5' Rotary cutter, 64" Sovema tiller
I'm going to have a mix of implements. A JD blade, tiller and box blade and TSC rake, boom, etc. I was wondering in this situation what would be most convenient?...MM
   / I-Match or Pat's Quick Change? #19
IMO, the Speeco is the way to go. It is essentially identical to the JD Imatch, it just gives the added benefit of having an adjustable top link. Good luck!
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
XCMG CV83PD (A53317)
