I-Match. What do you think?
   / I-Match. What do you think?
Thanks all. I have a JD weight box that is a real pain in the patoot to put on and off. I have adjustable links on my 3PH, but I hate to jockey around for 10 minutes.
   / I-Match. What do you think? #12
I cut that time to closer to 10 seconds with the addition of the I-match. In fact, I attribute the quickness to the fact that I now carry the ballast box more than when I didn't have the I-match, and that makes the tractor with FEL (bucket and forks) safer to use. Too often was finding I was a bit light in the rear end when carrying a load in the FEL, just because I didn't have the ballast box on.
As fast as you can back up, lift the 3pt arms, and lift - - is how fast you can have the ballast on (then just reach back and flip the latch levers down after the box is raised).
   / I-Match. What do you think? #13
Go to Northern Tool and Supply and TSC. They all have or can order bushings for about 15$ a pair.
I hate it when you are going down a hill with a bucket load of gravel in 2WD and no ballast and you try to hit the brakes. /forums/images/graemlins/blush.gif
   / I-Match. What do you think? #15
I was considering buying a Speeco from Mills Fleetfarm. Why is the Imatch better? is it worth the price diff?
   / I-Match. What do you think? #16
How does top & tilt work with this system?
Yooper Dave
   / I-Match. What do you think? #17
All you have to do is buy two sets of bushings and insert one inside of the other to get the right size. Total cost is about four bucks. I really like the imatch and I use it with a tiller. Even thought you have to manually connect the PTO the time to hook up is nominal.
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53472)
Kuhns AE10 Small...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
