I need a wiring harness for a B64 Blizzard Snow Blower
   / I need a wiring harness for a B64 Blizzard Snow Blower #1
garry
Bronze Member
Ohio
JD 1050
I have a Blizzard B64 3point snow blower that has an electric motor to rotate the chute. I need the wiring harness that goes from the Snow Blower to the tractor. Any idea where I might find one?
   / I need a wiring harness for a B64 Blizzard Snow Blower #2
That's easy.
DPDT center off spring loaded switch and 2 wires.
A 15 v amp fuse on hot side.
Thanks, I just needed a place to start.
I understand what you are saying and I have researched how DPDT switches work. I have learned the motor is a Ford power window motor. I have acquired a 5 pin power window switch. Now my question is, can I power the motor directly thru the switch or do I need to use relays?
   / I need a wiring harness for a B64 Blizzard Snow Blower #6
Gmail
If this works* the switch shown is a DPDT spring loaded center off and is less then $10. and will handle your amperage.
Diagram shows how to wire.
My blower is controlled this way and has run just fine for over 5 years.
Fuse at 10 amps and I'd suggest 16 g wire.
(15 amps protects the wire gauge, but 10 amp covers most switches plus suspect your motor draws much less)
*(Think it did!)
(Updated from earlier post. )
Thanks for the reply. I got an error on your link. I have a Gmail account and I am signed in. 403 error says Your client does not have permission to get URL
   / I need a wiring harness for a B64 Blizzard Snow Blower #8
Sorry 'bout that.
I'll try to describe how to wire.
The DPDT switch will have 6 tabs.
You wire the outer 4 in an X fashion with a pair of outer lugs/tabs going to your motor.
The power from the battery gets wired to the 2 center tabs.
Flipping toggle in one direction will rotate one way and in the opposite direction the other way.
Just be careful that when you cross over that the X is insulated or provide good clearance.
As mentioned earlier that is a center off 2 way spring loaded switch with 6 tabs or lugs.
Can be found in toggle or rocker styles. (I prefer toggle USA quality, but that is a personal preference.)
2007 LBT Hot Oil / Asphalt Tanker Trailer (A47384)
2007 LBT Hot Oil /...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
Bale Ring (A50515)
Bale Ring (A50515)
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
