I need advice re removing FEL
   / I need advice re removing FEL #11
I made a copy of the procedure and tacked it up in the garage. Now I don't even look at it. The loader comes off for mowing, then back on, Must have removed and put back on a dozen times this year so far. I feather the joystick while pulling on the pin that is on the same side. You can feel when the pin is ready to slide out. The other side sometimes needs additional movement but it's no big deal. Installing is the same way - eyeball the holes, get the pin ready and when you hit that sweet spot, in goes the pin. Like anything else, there are little tricks you learn and the more you do something, the easier it becomes. Since 2005, I've never disconnected without relieving the pressure first. Hope I can continue.
   / I need advice re removing FEL #12
HODAK said:
... Since 2005, I've never disconnected without relieving the pressure first...
How do you relieve the pressure?
   / I need advice re removing FEL #13
Turn the tractor off and jiggle the joystick around. THEN disconnect the hoses after the loader and bucket stop settling.
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
2016 Toro Workman GTX Utility Cart (A56857)
2016 Toro Workman...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
