louis Wedimer
I purchased the repair manual when I bought the tractor from a local dealer. The dealer does not have the Mahindra on his lot now and I do not want to use him for several reasons. I need to change the oil on the transmission and found a small drain plug on the 4wd linkage box in front of the transmission on the left side of the tractor. I think the oil drain on the transmissions / differential will drain the transmission but the 4wd linkage box may not drain. I can drain it but can not find a fill port. Also the fuel heater has not worked since I purchased the tractor and the dealer was of no help. I have the circuit and can trace it down but identifying the proper relay in the cluster in not in any document I have.
I have asked the factory for a better pdf repair manual and they told me that you have to be a dealer to obtain this manual.
Any help will be sincerely appreciated.
Thanks Louis
Thanks Louis
