escavader
Veteran Member
I need some advise on drilling 1 inch holes in1/2 thick steel,on my thumb project.I got 12 to do,cant even finish one /forums/images/graemlins/frown.gifI started by drilling 3/8 holes,should i go even bigger,or in sucession 1/2 then 3/4?I will go a little ways good,and then my bit must overheat,and wont cut no more.I have reground 3 times,and i cant even get one through.Im using a small drill press,to drill the parts with.I was worried about going too big first,and having the bit not self center.I was trying to keep oil on the bit,with little luck.Should i keep dipping the part in water.Whats the tip? Drilling is the only accurate way for me to make these holes.I might add,i have my press on the slowest speed.Like i said ,i will sharpen the bit,it cuts great for 30 seconds,then it gets dull from the heat i guess.Please give me advise,for proper procedure,in drilling these large holes.
ALAN
ALAN
