I NEED HELP PLEASE... I was told this was the place to come
   / I NEED HELP PLEASE... I was told this was the place to come #21
Step one would be visit the JD store and tell them what you want to do with the tractor. Ask what they have used, and what they will work on if something serious breaks on another brand tractor. See what routine work needs to be done on anything you buy, and how much of it you can do yourself. Ask about what electronics the tractor has that could fail and leave you hanging.
If you're going to be running around in the woods with the thing, check the belly side of the tractor for soft parts that could get torn up and leave you stranded far from help -- hoses, wiring, fuel lines, etc.
   / I NEED HELP PLEASE... I was told this was the place to come #22
If money is really most important, then you should consider the second tier companies like Kioti, Mahindra, Branson, TYM, and Agco. Many times, a lot more tractor for a lot less money.
   / I NEED HELP PLEASE... I was told this was the place to come #23
I'm still thinking about it and since your place is near Clark's, you should definitely go by there and talk with a salesman about your needs. I think you'll find that if you get a bigger machine, 50+HP, you'll find uses for it. But, for what you mentioned, a 30-40 HP machine will get you by for now.
Get the tires loaded with "goop" to thorn proof them if you have thorns.
   / I NEED HELP PLEASE... I was told this was the place to come #24
IF there is a dealer close by willing to work on these machines...
   / I NEED HELP PLEASE... I was told this was the place to come #25
Nearest Kubota dealers are:
A & B Implement Company, Inc.
Approximate distance from your zip code: 19 miles
6507 South US Hwy. 377
Dublin , TX 76446
Phone: (254) 968-0911
Fax: (254) 968-4155
Zimmerer Kubota & Equipment, Inc.
Approximate distance from your zip code: 62 miles
2825 N. Nolan River Rd.
Cleburne , TX 76033
Phone: (817) 645-9106
Fax: (817) 517-7808
There are Case, John Deere and New Holland dealers which you may want to visit in Stephenville.
   / I NEED HELP PLEASE... I was told this was the place to come #26
TexasOaks said:
We will definately go and take a tour.
Thanks Npaden
Since you are in Denton, I have to mention that I have not been too impressed with the local Deere dealer on Dallas Drive because they are more of a lawnmower place than a tractor dealership in my opinion. I do like Zimmerer Kubota on Loop 288 and also G&G New Holland on Fort Worth Drive. Both of those places have always been friendly, helpful, and well informed. Of course, that was several years ago when I last had dealings with any of them.
I'm sure that between Denton and Comanche Counties, you can find lots of tractor places to look, but if you have a good Deere dealership close to your property, that would be hard to beat.
Welcome to TBN. There is a very large Texas contingent here with lots of info and local "flavor" to be enjoyed. Heck, some of those non-Texans aren't half-bad either.:D
   / I NEED HELP PLEASE... I was told this was the place to come #27
Ill represent the blue guys....
TC40 (45/55) seems about right. 40 to 55 hp depending on which motor.
Standard 4x4, FEL with QA bucket.
my list would be
tractor with QA FEL R1 tires.
dual rear remotes
6' toothed bucket
6' rock bucket with grapple
7' rear blade
6' box blade
pallet forks
boom pole
6' to 8' brush hog
the large frame means it would easly support a smaller 3pt back hoe but they run 3500-5K addtional.
Quality machine but the above setup is likely to set you back in the neighborhood of 30K.
Thanks for the replies guys all good stuff.
That is crazy jinman you know all the denton streets. I might browse the local denton dealers just to get more of feel for the market, thanks.
Kyle, thanks for the tire goop, we do have lots of briar.
Coasterez, how reliable are those brands, that is really important to me?
DeTeacha, good call on the under belly, thanks.
Froggy I will see if they have a website to browse on to see their inventory, thanks for the heads up
Fug1000, I agree with you with 30-40 hp especially with my price range and the amount of land I will actually be working on, more leaning toward 40 though. Also with 4wd I here it adds about 10 more hp to ground usage.
Schmism, I dont know what the guys in blue is yet, but will have to check them out, thanks.
Keep the information coming if more stuff comes up you want to add; all is much appreciated. Right now I am reading a lot of stuff and trying to process it, got two books and John's stuff, but you get really good information from people actually owning tractors and working with them.
I saw to JD990's go for $17,000 4wd with loader 195 hours and the other with 640.
How do I post pictures BTW?
   / I NEED HELP PLEASE... I was told this was the place to come #29
Generally speaking, I think most of those second tier brands are just as reliable as any other. Many times initial problems come from proper dealer prep. before delivery. So, it is important to pick a good dealer. The real risk with these is whether or not the company/dealer will be around for you for the next 10 - 20 years. For the most part, these are well established international companies. They clearly are not "fly-by-night" outfits. Kioti is now celebrating 20 years in North America. Others have beens supplying tractors and parts to some of the BIG 4 makers for decades. So, if you can find a healthy, quality dealer close enough by, then I think you would be very happy with any of these machines.
But, I strongly suggest you read the forums, test drive many, and draw your own conclusions. Just don't do yourself an injustice by only considering the BIG 4. However, if money is no object, then buy the one you like best.
207277 (A52708)
207277 (A52708)
2019 CATERPILLAR 926M WHEEL LOADER (A60429)
2019 CATERPILLAR...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
